Thread: Dura-Glass Pump Mounting Plate Question
Threaded View
    Mar 2014
    Southern Cal
    Default Dura-Glass Pump Mounting Plate Question
    Hi,
    I'm replacing a 2HP A.O. Smith K48 motor that runs a waterfall. It seems to be shorted internally, tripping the breaker when I start the pump. I've checked the caps and switch and they are good, so I think the motor is toast.
    I've removed the pump and have the impeller off, but the motor mounting plate looks different than any I've seen online.
    Photos of the pump are posted here:
    I need to remove the pump seal from the shaft so I can then remove the copper cone and the mounting plate, but I'm not sure how to get the seal off the shaft. There are no screws holding the mounting plate to the pump, as I've seen in some pump pictures.
    Thanks in advance for any advice.
    Kit
    San Diego, CA
