Exactly although technically water can only be pushed and not pulled but that is a minor point.
But AG pumps are generally much smaller than similarly labeled IG pumps so for most situations I would not recommend an IG pump for an AG pool unless it is the smallest in the production line like the 1/2 HP Superpump or the 3/4 HP Superflo or the AG pool is very large. Otherwise, the pump is likely to be over-sized for the filter and pool. Plus you can get a much better deal on an AG combo setup than you would with IG components.
