1. Is the OFF pressure different than the ON pressure? (If not, you probably need a new gauge.) What is the ON pressure?
2. What HP pump? What size piping? (1.5" or 2")
Not sure about the Start / Clean marks -- I'm pretty skeptical about those. Normally, you should note your 'clean' ON pressure, and then backwash after you see a 4 - 6 psi increase. But, the initial ('clean' ON) pressure will vary from pool to pool depending on piping, filter, and layout.
