Re: First time poster - excited to use BBB method but have a question!
Can you return the "Super Tabs"? Generally , you'll find no love for combo action product around here. This product is worse than many because they don't tell you what is in it. 79.2% Trichlor, 20.8% Secret Sauce. As CarlD points out, your pool already has pretty high CYA and Low pH has been a problem. It's probably best to avoid stabilized chlorine altogether.
Sorry, I know of no tabs that don't add stabilizer. Most of use bleach or liquid chlorine (same thing, LC may be stronger) which adds only chlorine and a little(not enought to ever worry about) salt. Another popular option is Calcium Hypochlorite which adds chlorine and calcium.
The most important thig to do to set yourself free of the chemical store is to order a Taylor K-2006 (or K-2006C). If you order through the link in PoolDoc's sig (above) the form gets some coin to keep the lights on. Next this is to read all you can here and at pool solutions.com. The BBB and Best Guess links in PoolDoc's Sig are great for starting.
Good luck, we're here to help.
