Correction: Cal Hard is 370
I went back and retested :-)
I will also do a Phosphate test tomorrow.
I will start the search for a bleach supplier ASAP. I got nuttin' at the house right now.
Unless you have a Taylor phosphate kit (preferred) or the Aqua-Chek . . . don't bother. The other kits I checked aren't accurate enough to be useful, unless your goal is simply to sell phosphate remover!Taylor Technologies K-1106 Phosphate test kit
Hach Company 562227 Phosphate Test Kit (Aqua-Check)
Pool store bleach, purchased this year, should be fine -- heat cooks of bleach, but it hasn't gotten hot, yet. Still, Walmart bleach is likely to be fresher.
Pool store tablets (trichlor) may or may not be OK -- read the label. Borates are a way to dilute the tablets so the store can make more $$, but they won't cause any pool problems at all. Copper is altogether different -- do not buy any chlorine with copper listed.
Pool store dichlor should be avoided -- almost all of it is now badly diluted, and some of the chemicals used WILL cause problems.
PoolDoc / Ben
