Unfortunately, no one here is an Aqualink tech!
Pool electronics issues are a problem for us, because there's so much variation between manufacturers and even between models. I'll put your post in the right section, and maybe you'll get lucky and a get a response from a tech-savvy pool owner who's seen the same problem.
But I think you'll need to find a tech. However, you can try calling Jandy / Zodiac and see if they will help:
http://www.zodiacpoolsystems.com/Pro...-OneTouch.aspx
They have posted a pretty extensive trouble-shooting manual:
http://www.zodiacpoolsystems.com/~/m...1071/6919.ashx
But you'll need to know your way around a good multimeter to use it.
Contact info from the manual: Jandy Pool Products, Inc.
6000 Condor Drive, Moorpark, CA, USA 93021 • 707.776.8200 FAX 707.763.7785
