Thread: Aquapure/Aqualink salt system
    Default Re: Aquapure/Aqualink salt system
    As you can see, the code is a salinity probe error, which generates a bogus flow error code as a side effect. Dunno about the 102. Sounds like it's time to call Jandy, since you are in warranty.
    The full manual is here: http://www.zodiacpoolsystems.com/~/m.../H0325600.ashx
    Apr 2014
    Florida
    Thanks for the info. How can I tell which cell or sensor is the issue or are they both having problems? The oldest goes into the aquapure and the newest goes into the aqualink. Aquapure says service with the error codes and aqualink says no flow and shows no codes.
    in-ground pool
    If you have 2 cells, I would assume you can disconnect one at a time, and then see if the error is still thrown. But I've never worked with Jandy controls or cells, so I don't know for a fact that you can do so.
    Apr 2014
    Florida
    No I tried that and just gives a new error code. I ordered a new cell and flow sensor. I will let you know if that works. Thanks again!!
    in-ground pool
    Thanks . . . and good luck!
