Re: Testing & treating pool fill water
The new liner is being delivered Tuesday. They will probably come start draining the pool tomorrow. Today I'm painting the aluminum coping. I've ordered the polyquat and HEDP and some stabilizer.
I am planning on learning to use the BBB method this summer. I still have a box of shock and a bucket of trichlor tabs. We have an inline chlorinator. I also have a few gallons of Costco chlorine that I use for many things around the house, but can use it to chlorinate the pool.
I imagine that I will keep using the inline chlorinator this summer, but I won't shock on a regular basis. Shall I use the shock as startup chlorine for the pool? I'll mix it with water in a 5 gal bucket before adding it to the pool.
How does the type of chlorine affect the amount of stabilizer? Either way, I'm up for good advice on chlorinating and stabilizing
Thank you!
In-ground vinyl pool ~23,000 gal. Sand filter with zeosand.
