Thread: Neglected Vinyl AGP with Dead Dried Algae
    Default Re: Neglected Vinyl AGP with Dead Dried Algae
    1. What sort of pool do you have? A Whisperflo is usually an in-ground pump, but it sounds like you have some sort of above-ground pool.
    2. If it's an AG pool, it would probably be easier to clean after it was erected and partially filled. It would also be better for the pool -- leaving a pool liner laying folded in the sun isn't a good idea.
    Apr 2014
    Rancho Cordova, California
    Default
    Thank you for a prompt response. I am so glad that I found this forum and became a subscriber. I need all the help I can get. It is an above ground pool 20’ long x 12’ wide and 48” deep. There is no manufacturer name or anything to indicate size, model, etc. It has the “No Diving” signs but I haven’t found anything else. I didn’t know that it isn’t good to let a vinyl pool dry out. I will set it up in a temporary location this evening. I have another pump and filter I can use for the cleanup.
    You are correct about the pump and filters are used for in-qround pools. The seller sent me some photos of the pool and that shows them hooked up. I did the pool volume calculator and it only holds 7200 gallons. According to the chart for the cartridge filter the residential flow GPM is 90. The turnover capacity gallons for 8 hours is 43,200, 10 hours is 54,000, and 12 hours is 64,800. That is a lot for the size pool. Why would someone install a pump and filter that size pool? Will it cost a lot more to run than the normal recommended size? Should I keep them or sell them and replace with something else? I already purchased new cartridge filters, replacement rings for Pentair Rainbow Chlorine/Bromine Feeder #320, 3” trichlor tablets. and cleaned the filter and pump.
    Please only use this thread. Watermom has noted that the other one you started is identical and we like people not to do that.
    Please forward the pictures you have to [email protected]
    Apr 2014
    Duplicate thread. I had just ordered a subscription and received the confirmation e-mail when I submitted the first one. I went to check to see if it posted and couldn't find it. I did a search and I went through the different forum subjects. I even logged out and logged back in and never found it. Sorry.
