Results 1 to 10 of 18
Thread: Newbie - with cloudy pool
    Jul 2013
    In the Bayou Country, Louisiana
    Default Newbie - with cloudy pool
    Hi all! We have had our pool for about 5 years. It is a True L shape vinyl liner pool that is 16x36x41 in size with a deep end of 9 feet. We went with the True L due to the difference in ages of our children and the fact that we had a larger area for the younger one to play in and also have room for the older one to enjoy the deep end. We have a salt water converter on our pool and in the last 5 years we have replaced the salt cell (last year), hayward pump twice (also last year for the 2nd time) and the mother board in the salt converter twice. Seems it is always something breaking with our pool. I believe this year we need to change out the sand in the filter which doesn't sound very fun but I am sure will be needed.
    Opening the pool this year, it is very cloudy. I have been able to shock the pool and then use EZ Chlor Drop Out and the debris all settles to the bottom quickly and vacuum to waste. For some reason not having luck with that this year.
    Hope to continue reading to get help with our pool issues. Thanks!
    True L 16x36x41 vinyl 32K gal pool; PF=3.8
    Default Re: Newbie - Introduction
    Welcome and thanks for the subscription!
    Do you have a good test kit that you can use to give us some good, current water testing results? Not test strips. The kit we recommend is the Taylor K2006 or 2006C which you can get through the link in my signature below.
    What all have you added to the water, meaning ingredients, please.
    What is the volume of your pool?
    1. As Mom said, you need a kit.
    2. It's not normal to lose your pump 2x in 5 years, unless it's lightning or thunderstorm related voltage surges. Which Hayward pump?
    3. Sand does not normally need to be changed. BUT, if your pump is too big for the filter, you may have lost sand with each backwash, and my need to ADD sand. Insufficient sand will lead to a persistently cloudy pool. Which filter?
    Jul 2013
    Thanks for the replies! Working on getting a test kit so I can get accurate readings. Our pool is right at 40,000 gallons. And we have seen sand in the area where the pool backwash line is located. We have a Hayward Super Pump - 2 HP. That is what the original one was and that is what we replaced it with. I believe the 2nd one we had was a no-name brand that the pool man found lying around and put on just to keep us quiet. I have added 6 - 1 lb bags of pool shock that is 73% available chlorine and 27% calcium. Pool shock is non- stabilized. Then I added 2 bottles of EZ Chlor Drop Out. The water is blue but is very, very cloudy.
    I will post readings as soon as I get my test kit.
    Are you sure it's 40K, or is that the volume at overflow?
    I ran the calcs for typical dimensions, and it came out to ~32K, or maybe less. What is the actual water depth in the shallow part of the L? Which is the deep length -- 36' or 41'? What's the actual water depth in the hopper (deepest part)?
    OK, other issues.
    1. Make / model of the filter? (Pump may be too big for filter.)
    2. Make / model of the pump OR amps and SF (Service Factor) of motor?
    Meanwhile, chlorinate your pool with 1 - 2 gallons of plain store-brand 8% household bleach added each EVENING. Hold off on the cal hypo you have -- your calcium and alkalinity levels may be high. Wait for the the kit.
    If you have a top mount filter, pop the top, and check the sand level.
    Take pictures of the pump, filter, and piping, and post them using Picasa, Flickr, or Photobucket links, or by emailing them to [email protected].
    Jul 2013
    Default Re: Newbie - with cloudy pool
    According to the pool place that put it in and the other local pool stores who get pretty close to the same numbers at 38,772 gallons. It's 3.5 deep in the shallow and 9 feet in the deep.
    Hayward Super pump model no SP2615x20
    And emailing the pictures now!
    Thanks!
