Results 1 to 10 of 12
Thread: Question concerning Pool Pump replacement
    Default Re: Question concerning Pool Pump replacement
    By the way, whenever new members post, their posts go into a moderation queue to wait until one of us reads it and approves it before it will appear on the forum. We try to do it as quickly as possible but sometimes it may be a little while til we get to it. But, never fear, we will!
    (I deleted your duplicate posts.)
    Jun 2013
    Louisiana
    Thank you! I figured that out after i sent the second or third one. LOL Y'all are doing a great job and i really appreciate all the help! Will be contributing to the cause soon. When will the moderator queue's go away, or will they? I remember something about autheniticating myself or something like that but havent' had time to due to work. Thanks again
    25k gal FG pool; Sta-Rite P2R5AE-124L pump pump; Pentair TR-60 24" sand filter; 3 returns via one 1.5" pipe; suction piping is two 1.5" lines
    MaxFlo XL vs Super pump:
    If you compare the data on the 3/4 HP full rate / 1 HP uprate pumps (SP2607x10 vs SP2307x10) you can see that the MaxFlo XL is a bit more efficient.
    I'm not sure you realize how much a 2 speed pump will save you. It sounds like you do not have a timer on your pump, so you're operating 24x7 (that's fairly normal in areas with lots of summer rain and thunderstorms to dirty up your pool!) On low speed, pumps typically use about 1/4 the electricity to move 1/2 the water. In your case, assuming a high speed wattage of 640 and a cost of $0.10 per KWH, 6 months of pump operation will cost you ~$280. per year. If, instead, you run your pump on low speed 95% of the time -- 24 GPM instead of 48 -- you'll save about $130 per year.
    So, in one year, you'll pay back the additional costs of the 2-speed.
