Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
Thread: Replacing cartridge with sand
    May 2013
    Concord,ca
    Default Replacing cartridge with sand
    Is it possible and worth doing to replace my Hayward cartridge with sand filters? I heard they are better but I know nothing about it
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    Default Re: Replacing cartridge with sand
    I can't help you with how to replace it but will tell you that sand filters are WAY easier to maintain. I think you'll be glad you switched!
    Welcome back to the Pool Forum for another season!
    BigDave's Avatar
    I'm with Watermom, I love my sand filter. That said, why do you want to change?
    May 2013
    Concord,ca
    pool isn't all that clean and I read where sand is better but I don't even know where to start. If I have to backwash, don't know what to do and would have to be repiped which is not a problem. I just don't know if Im opening a can of worms Im going to wish I didnt
    BigDave's Avatar
    What kind of cartridges do you have? Many cheap knock-off carts don't do the job no matter how much they cost. Filbur, Unicel, or OEM are the only ones recommended here: Recommended equipment for new inground pool.
    The advantage of sand over cartridge is the ease of cleaning the filter. For a sand filter, you simply turn a handle on the top of the filter a couple of times. The whole process takes about 2 minutes tops. Simple, simple. Personally, I will never have anything but a sand filter.
    Largo, Florida
    I was under the impression that cartridge filters smaller particles that sand does not. Am I mistaken?
    Cleaning my cartridge probably takes 10 or 15 instead of 2.
    May 2013
    Concord,ca
    my cartridges come from my pool store and I believe they are unicel
    BigDave's Avatar
    If you have quality carts that are in good shape and you're still unhappy with water quality you could try using polyquat 60% to see if it helps filter some of the smaller bits.
    An oversized sand filter will filter better than a smaller one (as long as it can be backwashed). With sand you can also polish the water with a little DE to catch finer bits than the sand can by itself.
    Some parts of California have water use issues. Is water use limited where you live? Sand filters require occasional backwash - dumping water which must be replaced.
    May 2013
    Concord,ca
    I'm not sure of the water quality Dave but I do have a fresh bottle of 60% polyquat here. I will give it a try. Thanks one Dave to another
  1. Sand vs Cartridge filter
    By Reefdiver in forum Pool Equipment & Operations
    Last Post: 07-27-2011, 10:57 AM
  2. Replacing sand in my sand filter?
    By Txboynjgirl in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2011, 10:30 PM
  3. Sand to Cartridge Filter
    By PowerOut in forum Pool Equipment & Operations
    Last Post: 06-05-2010, 08:28 PM
  4. Replacing cartridge filters with generic brand
    By kearpaul in forum Pool Equipment & Operations
    Last Post: 09-20-2007, 07:01 PM
  5. Sand vs. Cartridge
    By hunter580 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-23-2006, 03:20 PM
