Results 1 to 10 of 22
Thread: Bleach Calc
    Default Re: Bleach Calc
    Quote Originally Posted by michladny
    I have looked high and low for this Bleach Calc but it does not want to be found and any link I have clicked on says the page is no longer available.
    Anyone have the working link to the Bleach Calc?????
    THANKS
    Michelle
    FORGET IT, I FOUND IT I see you have to convert liters to gallons (1 liter = 0.264172051 US gallons)???? is this right?
    With the standard bleach calculation forumula, if BOTH your pool volume and your bleach are measured in liters, you don't need to do any conversion. As long as the units are the same for both items, the forumula works. If one of the two is in liters and the other in gallons you need to convert one or the other.
    I'm not sure if that's true in Michael's program, if he allows you to set one to gallons and the other to liters and then does the conversion for you. He certainly allows you to pick which units you are using. But he's the expert on it--not me.
    Katy, TX
    Yep, in the default settings, you can set you default pool size, bleach strength and unit of measure. It will switch the whole program from US (Imperial) to metric, or vice versa. Mainly implemented for our friends across the pond.
    I'm thinking now that I should have the program check to see if the registry key is set upon start up, and if not, to force the inital setting of the defaults.
    *** adds that to his list of things to do ***
    Michael
    c130jake Guest
    Any Mac or Palm versions of Bleach calc?
    Jake
    Katy, TX
    Quote Originally Posted by c130jake
    Jake
    No. Not because I wouldn't, but I don't have the hardware or the development environment.
    Michael
