If you post water testing results, someone will be happy to help you determine if any adjustments need to be made.
Using bleach will not fade swimsuits. Bleach is 8% sodium hypochlorite whereas many pool stores sell liquid chlorine that is 10 or 12% sodium hypochlorite. People seldom are concerned about buying and using pool store liquid chlorine but get scared upon hearing the word 'bleach.'
We generally suggest either pouring it directly into the skimmer while the pump is running or in front of a return jet. Either way, the bleach will quickly be dispersed into the volume of the pool.
Hope this helps!![]()
