Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 35 of 35
Thread: New to the Forum
  1. #31
    Default Re: New to the Forum
    IMO, the easiest way to add stabilizer is to use dichlor. If you buy a 24# pack of bagged dichlor at Sams Club, and use 15#, you'll have a CYA level of about 45. You can gradually use the rest to maintain stabilizer.
  2. #32
    Apr 2014
    South Carolina
    Algae is dead, liner is repaired, pool is filled, and the water is clear.
    I ran the tests a few minutes ago:
    FC - 19.5 PPM
    CC - 1.5 PPM
    PH - low (Acid Demand test - 6 drops to 7.4~7.6)
    TA - 20 ppm
    CH - 30 ppm
    CA - 45~50 ppm
    My thought was that TA would be the best starting point, is this correct?
    20K gal 30ft AG pool; PF=6
  3. #33
    pH first!
    Add borax, 3 boxes at a time, till you reach 7.0. Then 1 box at a time. Retest your TA *after* your pH reaches 7.4.
    Add it slowly, since a borax plug in a pipeline is VERY hard to dissolve. (As long as the flow through your skimmer is not getting 'choked' you'll be fine.)
    But . . . when you retest pH, do so using a 50:50 mix of pool water and DISTILLED water. FC=19 is high enough to affect readings with phenol red.
    (distilled water at Walmart => www.walmart.com/ip/10315382)
  4. #34
    Apr 2014
    South Carolina
    I wanted to give the pool a little time for the chlorine levels to drop. With my CYA levels, I think I should be running between 3ppm and 6ppm FC.
    Here are the latest test results...
    FC - 3.5 PPM
    CC - 0.5 PPM
    PH - 7.2 (Base Demand test - 3 drops to ~7.6)
    TA - 40 ppm
    CH - 40 ppm
    CA - 45~50 ppm
    When adding Borax, how long should I wait between application and testing?
  5. #35
    Quote Originally Posted by Traxl View Post
    There's no definite answer; a really 'good' answer would depend on observing circulation in your individual pool.
    But, 4 hours of pump 'ON' should be more than enough.
  1. New to the forum
    By DanMan in forum Above-Ground Pool Construction & Repair
    Last Post: 07-22-2012, 11:42 PM
  2. New to Forum
    By jmajtyka in forum General Interest
    Last Post: 07-20-2012, 08:35 PM
  3. New to forum
    By KFollen in forum Above-Ground Pool Construction & Repair
    Last Post: 06-20-2012, 08:49 PM
  4. New to this forum
    By bssage in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-21-2012, 12:31 AM
