Page 3 of 3 FirstFirst 1 2 3
Results 21 to 28 of 28
Thread: Overwhelmed
  1. #21
    Default Re: Overwhelmed
    I agree that your numbers look good. My only comment is that if you find, once the heat of summer gets here, that you are having trouble keeping chlorine in the pool through a hot sunny day that you might want to bump your CYA up some. You may not need to but just keep it in mind if you start ending up with your chlorine level below the needed minimum (per the Best Guess Chlorine Chart) at day's end.
    Good job!
  2. #22
    BigDave's Avatar
    Looks like you're not so Overwhelmed any more. Congrats! Have fun!
  3. #23
    Apr 2014
    Mobie, AL
    Default Readings
    Yesterdays readings are:
    FC 5 ppm
    CC 1 ppm
    Alkalinity 7.6 pH
    CYA 42
    Please advise.
    Also, someone stated raising stabilizer. How do I raise that again?
    AG, 7,000 Gallons, K-1000 and K-2006 Test Kits
  4. #24
    Default Re: Readings
    40 ppm CYA is OK.
    5 ppm FC is OK. 1 ppm CC is probably a testing error, unless you are 'smelling' the pool.
    You can raise CYA by dissolving cyanuric acid into the pool -- a sock works well for soft side pools -- or by using dichlor or trichlor, which add almost a ppm of CYA for every ppm of chlorine.
  5. #25
    Apr 2014
    Mobie, AL
    So should I add just one "dose" of dichlor? or two? and should I ALWAYS do equal amounts of BORAX?
  6. #26
    You add dichlor to raise chlorine. It also raises CYA.
    You add borax to raise pH.
    You only do either, when you want to affect the particular pool factor. I usually try to size 'doses' to give them a reasonable amount to add at one time. But, that's assuming a 'test, dose, retest' approach, that corrects pool factors gradually.
  7. #27
    Apr 2014
    Mobie, AL
    Thumbs up Re: Overwhelmed
    I am super appreciative for all of the help. You guys and gals are awesome!
  8. #28
    Glad things are working well for you . . .
  1. Intex Owner 15' x 48" overwhelmed
    By ATC_NH in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-13-2012, 05:49 PM
  2. Overwhelmed by all the pool chemistry
    By darylrue in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 03-31-2012, 03:05 PM
  3. New here. A bit overwhelmed.
    By Mwil3 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2010, 06:10 PM
  4. Overwhelmed with pool chemistry
    By muundance in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-28-2006, 12:19 PM
