Results 1 to 10 of 28
Thread: Overwhelmed
    Default Re: Readings
    40 ppm CYA is OK.
    5 ppm FC is OK. 1 ppm CC is probably a testing error, unless you are 'smelling' the pool.
    You can raise CYA by dissolving cyanuric acid into the pool -- a sock works well for soft side pools -- or by using dichlor or trichlor, which add almost a ppm of CYA for every ppm of chlorine.
    Apr 2014
    Mobie, AL
    Default Re: Overwhelmed
    So should I add just one "dose" of dichlor? or two? and should I ALWAYS do equal amounts of BORAX?
    AG, 7,000 Gallons, K-1000 and K-2006 Test Kits
    You add dichlor to raise chlorine. It also raises CYA.
    You add borax to raise pH.
    You only do either, when you want to affect the particular pool factor. I usually try to size 'doses' to give them a reasonable amount to add at one time. But, that's assuming a 'test, dose, retest' approach, that corrects pool factors gradually.
    Apr 2014
    Mobie, AL
    Thumbs up Re: Overwhelmed
    I am super appreciative for all of the help. You guys and gals are awesome!
    Glad things are working well for you . . .
