Results 1 to 10 of 33
Thread: New to BBB
    Virginia
    Default Re: New to BBB
    Quote Originally Posted by TexasGolfer View Post
    ......I've also read that it may take several days after it's put in to register, which has me worried that even if I take them out, the level could keep rising......
    I don't think this is true. Once it has dissolved it should be measurable and won't keep rising, unless you add more. I think where the confusion may be is that when adding stabilizer granules separately (those who use unstabilized sources of chlorine need to add stabilizer separately) it takes time for those granules to dissolve, and so the stabilizer level will rise as the granules dissolve. Personally, I find I get a good stabilizer reading about 24hrs or so after adding stabilizer granules directly in the skimmer and running the pump the whole time (the granules get caught in the filter where they then dissolve).
    So measure after the pucks dissolve to see if you need to keep adding stabilizer.
    Certainly someone here will correct me if I'm wrong.
    No, I actually think JimK is right and it's a subtlety. CYA granules take a very long time to dissolve but Trichlor fundamentally contains CYA so as it's releasing chlorine, it has to be releasing CYA, too, and acid.
    BigDave's Avatar
    FWIW, dichlor (if you can find it pure) adds 9 ppm CYA for every 10 ppm FC and, unlike trichlor pucks, dissolves very quickly. One gotcha when starting new water is the sun will strip the FC quite quickly until the CYA has built up.
    Apr 2014
    Houston, Texas
    Cool! That makes sense. Thanks guys.
    12.3 K gal in-ground, gunite pool, Hayward C-5025 cartridge 150 gpm, Century Centurion 2HP 3450 rpm, Polaris 360
    Apr 2014
    Houston, Texas
    Thanks to you good folks here, the pool appears to be in great shape. Last time I added bleach was Wed night. I'm using triclor pucks to try to increase my CYA, but I can't get it above 30 yet. After adding nothing but triclor, here are my numbers this morning:
    FC: 7.5
    CC: 0.5
    pH: 7.4
    TA: 100
    CH: 325
    CYA: 30
    Almost identical to what I posted on the 27th. I should note that I turned the pump off for about 8 hours last night for the first time in two weeks. It kicked back on about 2 hours before I tested.
    So my question today is, should I just keep going with the triclor pucks, or use something else to up the CYA without raising the FC? I assume that 7.5 FC is too high for the long term.
    Thanks!
    You can keep using pucks if you want til you get your CYA where you want it. Just keep an eye on your pH. Trichlor is very acidic. A chlorine reading of 7.5 won't last too long in the Texas heat in a pool with low CYA so its not a worry. Besides, you have a gunite pool and higher chlorine levels are not a problem as they could be in a liner pool.
    Did you take a look at the Best Guess Chlorine Chart in my signature yet?
    Apr 2014
    Houston, Texas
    Yes, I've looked at the chart, and read everything I can find on the Pool Solutions site and here on the forum. Don't I want to get the CYA up to at least 50 pretty quickly so that I don't lose all the FC during those hot sunny days? It seems like with my low CYA level that I'm going to just keep dumping in bleach or using a lot of the pucks just to keep up with the daytime losses. Won't I use less chlorine in the long run if I have a higher CYA level? Not to mention the constant testing and adding chlorine? I want to get to the position where I don't have to test every single day.
    What is the position here on adding straight cyanuric acid to my pool? And what is the proper dosage and method of adding it?
    Having a higher CYA does allow you to go longer between testing and adding doses of bleach. There are several here on the forum who deliberately run a higher CYA pool for this very reason.
    You can definitely add straight CYA to your pool. I usually do so myself. In a pool your size, each pound of granular CYA will increase your level by about 10ppm. There are several ways to add it. One way is to just pour it slowly into the skimmer while the pump is running and then keep your pump running about 4 or 5 days after you add it to let it dissolve in your filter. But, with a cartridge filter, that might not be the best way. You might just want to put it in an old sock and hang it in front of your return jet. Every once in awhile, give the sock a squeeze to help it dissolve faster. That is probably the best way for you to add it. (The directions on some containers actually tell you to just broadcast it across the pool, but don't do that.)
