Re: Excessive Vibration/Noise in pump
That sounds like normal high speed (3600 RPM) pump noise, amplified by direct contact with the slab. Unfortunately, standard 3600 RPM pumps ARE intrinsically noisy.
Unbolt it, and slip a door mat under it. I think you'll find that greatly reduces the noise.
But, if you really want it to be quiet, convert to a two speed pump, and run on low most of the time. Low speed, on most pumps, uses ~1/4 the electricity, but moves ~1/2 as much water . . . and is much, much quieter.
