Thread: Does the thickness of solar cover matter
    rdefino is offline Registered+ Thread Analyst rdefino 0
    Jun 2013
    Haverhill, MA
    Default Does the thickness of solar cover matter
    I know that folks said to buy the cheapest since none of them will last anyways. But I read that 16mil compared to 8mil will retain heat better. Does this matter? Will it make a big difference?
    Also, where is a reputable online seller to buy covers and other supplies from?
    thanks
    BigDave's Avatar
    Default Re: Does the thickness of solar cover matter
    I don't think the thickness of the plastic makes much difference in heat retention; it's the air in the bubbles that insulate and the membrane that stops evaporation. Thicker plastic may be stiffer and easier to move on the water, it will also be heavier off the water.
    I once thought the thicker cover would help...and last longer. It did neither. I've decided they are a waste.
    Jun 2013
    Haverhill, MA
    Lowes??? They sell covers like these?
    My local Lowe's has a section with some pool stuff in the summer. Not a huge selection; just some basics. I think I have bought 2 or 3 solar covers there.
  1. Intex debris cover or solar cover
    By Larryh86GT in forum Pool Equipment & Operations
    Last Post: 06-12-2013, 06:06 PM
  2. Solar Cover Thickness, Reel Quality, Solar Panels
    By vector13 in forum Pool Equipment & Operations
    Last Post: 03-20-2012, 02:45 PM
  3. Solar Cover as Winter Cover?
    By CoffeeBean in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-02-2007, 11:46 AM
  4. Solar cover under winter cover?
    By margekendall in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-18-2006, 10:49 AM
  5. IG Liner Thickness
    By pmdelage in forum In-Ground Pool Construction and Repair
    Last Post: 04-02-2006, 01:24 AM
