Thread: Did I wire this correctly? just changed out my pump....
    May 2014
    Canada
    Default Did I wire this correctly? just changed out my pump....
    I am replacing my pool pump and just want to be sure I wired this correctly. I think my old pump was 120v and set my new pump to 120 as well. Both say they can be either 220/120.
    My old pump is a pentiar superflo.
    Here is the old pump with the old wiring setup and the wiring diagram from the pump.
    And here is how I wired my new pump a Hayward super pump
    - - - Updated - - -
    on my new pump i have the white neutral to L1 and the black hot wire to L2 I assume that is correct....
    May 2014
    Canada
    Default Re: Did I wire this correctly? just changed out my pump....
    btw i think i figured it out. the bottom picture I set it to 110 not 220. the old pump based on the pictures is set to 220.
    Largo, Florida
    Maybe test the voltage with a VOM? They can be had for less than $10 and are an invaluable tool for any homeowner.
    Please tell me that the metal flex I see in the last photo is a TEMPORARY hookup:
    (from http://healthybuildingscience.com)
    and that you are going to replace it with some type of LT conduit or UF cable!
    BigDave's Avatar
    Did you look close at the before picture? I know my electrical inspector would fail the original and the new BX.
    Yeah, I saw that. But I figured that's the past. It's the present . . . and that metal flex that worries me.
  1. Aqua Comfort S125 Heat Pump Not reading Water Temp Correctly
    By ghostcat in forum Pool Equipment & Operations
    Last Post: 07-20-2012, 11:12 PM
  2. Attaching Hoses Correctly
    By Steveromo in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-10-2012, 03:42 PM
  3. Bonding Wire
    By anotherpyr in forum In-Ground Pool Construction and Repair
    Last Post: 06-18-2007, 11:47 PM
  4. interesting re: pool pump wire guage
    By tenax in forum Pool Equipment & Operations
    Last Post: 07-01-2006, 02:20 PM
  5. PS234 First Test results... Am I doing this correctly?
    By leejp in forum DPD-FAS based testing
    Last Post: 05-24-2006, 10:12 AM
