Results 1 to 10 of 18
Thread: How can I remove the dead algae from an Intex 15' X 48"
    Default Re: How can I remove the dead algae from an Intex 15' X 48"
    Let us know!
    May 2014
    Plano, TX
    Got my Intex Plunger valves today. I might be able to use them to restrict flow, but not reliably. I think I have a plan that will be pretty inexpensive tho. I haven't ruled out adding a ball valve just before the pump.
    I have some pics of the conversion from the 1-1/4" line cartridge to the 1-1/2" line sand filter I can email if you'd like. I can put together a short "how to" convert, also.
    The pool is sparkling clear! Thanks!
    Please => [email protected]
    May 2014
    Plano, TX
    Pics sent. Should I start a new thread on "how to" change over to a sand filter?
