Thread: Too much algaecide in pool
    Apr 2014
    NE Penn
    Question Too much algaecide in pool
    I put way too much alg. in pool when opening. Now water will not clear up..What can I do? thx
    Default Re: Too much algaecide in pool
    Sometimes running high chlorine levels will break it down over time. Also, run your filter 24/7 while you are trying to clear it.
    This is one of the reasons we say only to use Polyquat 60% algaecide.
    Apr 2014
    NE Penn
    Too late for Polyquat...But I'll try high chlorine and filter 24/7.......thx
    Apr 2014
    NE Penn
    Quote Originally Posted by Earl J View Post
    Would u recommend clarifier? I let pump run for the past 30 + hrs...no improvement
  1. Closing pool, algaecide added and PH level real high now
    By tdurban in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-02-2013, 02:06 PM
  2. I've used HTH algaecide - do I need to drain my pool?
    By Whattf in forum Dealing with Algae & Slime
    Last Post: 08-16-2013, 01:55 PM
  3. algaecide
    By vinper in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-24-2013, 12:24 AM
  4. Is any Algaecide better than nothing?
    By NullQwerty in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-16-2006, 09:17 PM
  5. Can anyone tell about HTH Algaecide
    By poolboyforjenny in forum Dealing with Algae & Slime
    Last Post: 08-21-2006, 07:25 PM
