low to no pressure....help
I have an intex above ground pool.
I am using a hayward pump and sand filter. I have little to no pressure. I have replaced the sand in my filter and completely cleaned it out, I have primed the pump, I have made sure there are no clogs anywhere.
I have even hooked up a different pump and filter to the pool and I continue to have the same problem. I can not figure out what this could possibly be. the pr filter assembly does not fill completely up with water, and there seems to be surges in the pressure, where it will work great for a minute or two then the pressure slowly fades till it is not sucking anything into the skimmer.
My pressure gauge constantly reads zero,it does not move and this is the case with both filters I have had hooked up. I have backwashed and all the obvious things I could think of.
