Closed Thread
Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 51
Thread: Intermatic Pool Timer Wiring
  1. #21
    Apr 2014
    Rancho Cordova, California
    Default Re: Intermatic Pool Timer Wiring
    I bought the Intermatic T104 208-277 Volt Mechanical Switch from Amazon. It should arrive in two days. I also ordered 2 sets of on and off tripper pins. I forgot to mention that I can manually turn on and turn off the pump and the switch isn't loose, too easy or hard to push. I can hear the timer switch on and switch off by it self. I have to unplug it to stop the timer from turning on and off by itself at random. I have been keeping the pool clean from debris, vacuumed, and brush all sides of the pool. In the meantime, I will be working on getting the proper levels of chlorine and PH and whatever else I need to do to prevent problems. I will update this thread after I get the timer installed this Saturday.
  2. #22
    Thanks!
  3. #23
    Apr 2014
    The new Intermatic pool timer has been installed and works fine. I followed the instructions I found on You Tube on how to install three sets of tripper pins so the pump will run three hours a day. I can't thank you enough for helping me out.
  4. #24
    Great!
  5. #25
    Apr 2014
    After I replaced the pool timer I thought the problem with the pump turning on and off by itself was resolved. I should say assumed it was resolved. After installing the new timer Intermatic (T104) I checked to verify the pump turned on when it hit the first “on” tripper pin and went off when it hit the “off” tripper pin. I did the same thing with the second and third set of tripper pins and both went “on” and “off” on schedule. Then I changed one set of tripper pins to run the pump from 4 pm to 6 pm. I was in the pool when it turned on at 4:00 pm and after about ten minutes the pump shut off. Then a few minutes later pump turned back on. The pump ran for about five minutes and shut off itself again. I got out of the pool and checked the pool timer and the manual switch was in the “on” position. I realized the original problem was not fixed and the timer was doing its job. I did a search on the internet and discovered that the pump turns itself off when it overheats (thermal overload.) The possible reasons are the electrical supply connections are incorrect, low voltage because the gauge of the wires are incorrect, inadequate ventilation, or the motor is old because there is a short inside, usually across the windings. I ruled out ventilation so it is either the wiring or the motor. Should I check the voltage with my multi-meter to determine if the voltage is correct or just replace the motor? If I check the voltage can anyone provide instructions or can provide a website that does? I forgot to mention that the Pentair Clean and Clear Plus filter shows 10 psi when the pump is on. Is that normal?
  6. #26
    If you know how to do so, check the voltage while the pump is running.
    OR, engage the multimeter with the pump OFF, and then have someone turn it ON while you are watching the voltage. It shouldn't drop more than 3% -- 4 volts at 120; 7 volts at 240.
    It's harder to check for a short across the windings; you can check resistance, but unless you know the 'good' value, it may not tell you much.
    Do you have an ammeter? (Amp-meter)
    . . . I'm going to ask Mark to take a look; he understands electric motors better than I.
  7. #27
    mas985's Avatar
    Pleasanton, CA
    I doubt it is the winding's. Winding's are usually shorted or opened on failure so the motor will trip a break or won't run at all.
    If the pump is turned on but after a few minutes shuts off on it's own, then it is likely the thermal limiter switch tripping. This is caused by overheating in the motor which in turn is usually caused by bad bearings in the motor or even a problem with the impeller. Under voltage and over voltage can cause the problem as well but that is pretty rare. If you are comfortable checking the motor voltage, you should probably do that first just to make sure.
    Is the motor loud when running?
    How old is the motor?
    Mark
  8. #28
    Apr 2014
    I found instructions for testing a pool pump with a multi-meter at Inyo Pools website. I will test the pool pump this afternoon. Testing to check for a short across the windings sounds too complicated for me and way beyond my skill level. I don't have an amp-meter. If I have to replace my Pentair 3/4 HP Whisperflo single speed motor, can I buy a 3/4 two speed motor instead? Is the quality of an OEM motor equal to Pentair's replacement motors? I think the pool pump is at least a few years old. I have to see if there is a date on the pump and will update thread if its older.
  9. #29
    mas985's Avatar
    Pleasanton, CA
    Yes you can replace your current motor with a two speed. Is your pump the WF-3 or the WF-23?
    Pentair does not make motors, they usually use a branded A.O.Smith now branded as Century motors on their pumps which are also sold aftermarket.
    Mark
  10. #30
    The 2 speed motors are pretty expensive. Since you have a small pool, if your motor is shot, you might be better off getting a 2-speed above ground pump:
    Hayward SP15922S Power-Flo Matrix 2-Speed
    Here's a link for replacement motors:
    http://www.a1poolparts.com/-strse-Mo...Categories.bok
Closed Thread
  1. Intermatic T104 timer and Goldline GL-235 wiring help for bypass mode
    By netprotex in forum Pool Equipment & Operations
    Last Post: 05-14-2012, 12:16 PM
  2. Intermatic Timer.
    By Phillbo in forum In-Ground Pool Construction and Repair
    Last Post: 04-05-2009, 04:18 PM
  3. Polaris 180 and Intermatic Timer - Quick Disable?
    By aquarium in forum Pool Cleaning: Manual or Automatic
    Last Post: 10-02-2006, 01:47 PM
  4. anyone have time trippers from intermatic timer they will sell to me?
    By tenax in forum Pool Equipment & Operations
    Last Post: 07-05-2006, 08:26 PM
  5. Intermatic timer trippers
    By ScottS in forum Pool Equipment & Operations
    Last Post: 06-07-2006, 12:28 PM
