After I replaced the pool timer I thought the problem with the pump turning on and off by itself was resolved. I should say assumed it was resolved. After installing the new timer Intermatic (T104) I checked to verify the pump turned on when it hit the first “on” tripper pin and went off when it hit the “off” tripper pin. I did the same thing with the second and third set of tripper pins and both went “on” and “off” on schedule. Then I changed one set of tripper pins to run the pump from 4 pm to 6 pm. I was in the pool when it turned on at 4:00 pm and after about ten minutes the pump shut off. Then a few minutes later pump turned back on. The pump ran for about five minutes and shut off itself again. I got out of the pool and checked the pool timer and the manual switch was in the “on” position. I realized the original problem was not fixed and the timer was doing its job. I did a search on the internet and discovered that the pump turns itself off when it overheats (thermal overload.) The possible reasons are the electrical supply connections are incorrect, low voltage because the gauge of the wires are incorrect, inadequate ventilation, or the motor is old because there is a short inside, usually across the windings. I ruled out ventilation so it is either the wiring or the motor. Should I check the voltage with my multi-meter to determine if the voltage is correct or just replace the motor? If I check the voltage can anyone provide instructions or can provide a website that does? I forgot to mention that the Pentair Clean and Clear Plus filter shows 10 psi when the pump is on. Is that normal?
