Thread: Test Chemical/Reagent replacement
    May 2013
    Maryland
    Default Test Chemical/Reagent replacement
    Anyone care to offer advice on the frequency with which the chemicals in my K2006c should be replaced? I purchased the kit at the beginning of last season and I've got lots of everything left (except the CYA test chemical). Thanks in advance! Mike
    Default Re: Test Chemical/Reagent replacement
    You should be fine. Reagents actually last for awhile especially if they are stored in a cool, dry place. The powder occasionally goes bad but you'll be able to tell. It will turn gray and will be obvious that it needs replaced.
    Virginia
    I replace my reagents every other season, except for DPD powder I buy new every season since I go through most all of a 10 gram bottle in a single season, and haven't had any problems. I do keep them inside (climate controlled) and out of direct light.
    May 2013
    Maryland
    Thank you for the replies!
