Thread: newbie, salt pool, cyanuric acid (stabilizer) levels?
    May 2014
    Default newbie, salt pool, cyanuric acid (stabilizer) levels?
    I'm new to this forum but have been successfully looking after my salt pool for about 5 years.
    My salt cell (jandy aquapure) requires 50-75ppm for cyanuric acid levels (stabilizer)
    the obstructive guy at the pool supply place says the levels always have to be at the high end (75ppm) for a salt pool. I'm holding off on the last couple of pounds of stabilizer until I find out why that would be? I really don't want to put in any more than necessary. Why is stabilizer needed in higher levels in a salt pool?
    This guy has been insistent before about something and has been mistaken.
    Default Re: newbie, salt pool, cyanuric acid (stabilizer) levels?
    We're guessing at the reason, but here's what we think:
    + SWCG (salt water chlorine generators) have been less durable than the makers would like. This has shown up as they've reduced the warranty period on the units.
    + SWCG life is mostly a function of ON hours; lower the hours and the unit lasts longer.
    + At a constant chlorine level, high CYA reduces chlorine loss to sunlight. If you follow pool industry standard, you will have the same chlorine level at CYA = 30 as you do at CYA = 70. In the absence of algae, this will lead to less chlorine use, and less SWCG 'ON' hours.
    + So (we think) SWCG makers have latched on to this to make their units last longer.
    + But, maintaining constant chlorine levels over a varying CYA level is a HUGE mistake. This page explains more: http://pool9.net/cl-cya
    + We recommend the following:
    1. Buy the largest SWCG that you can put on your pool, and then turn it down.
    2. Never use your SWCG during start-up, or during an algae outbreak: manage those manually.
    3. Never use your SWCG to shock; pour a couple of gallons of bleach in, instead.
    4. Maintain chlorine levels in proportion to your CYA level; you'll need the K2006 kit in order to do so => http://pool9.net/test/
    Those 3 steps above are the CORRECT way to reduce SWCG 'ON' time, and prolong your unit's life.
