Re: New INtex AGP with saltwater...
Sounds about right. I don't know if you can turn off the SWCG but I would try.
The Super Simple Recipie http://pool9.net/ssr/ should be a pretty good startup plan. Follow the "Intex Pool Care Plan" using dichlor until you have sufficient CYA in the pool then you can let the SWCG take over; it won't be able to keep up with the demand in an unstabilized pool. According to the pool calculator, 4lbs of dichlor (3/4 Cup at a time) will get CYA to 55 which should be good.
Important! Buy a Taylor K-2006 or K-2006c test kit. Order it today, you won't find it in a store. If you buy it through this page:http://pool9.net/test/, Poolforum gets some coin to keep the lights on.
Note: As a trial user you'll need to copy the links above then log out and paste them into the browser address bar.
