Re: having trouble with a cloudy pool
I should have been promoting these videos more; watch them, especially the CYA (not: CYN) test, and see if you did it correctly. If you did, you have no stabilizer.http://pool9.net/tk-guide/
http://pool9.net/tk-interfere/
Also, post your pool dimensions. You entered your address, so I looked at your pool. Scaling off Google Maps photos is not very accurate, but your pool does not appear to be a 50k pool . . . so I can't figure doses for you. It looks like a 20x40 short L, but those are typically 30,000 gallons (20 x 40, 3.5 water depth in shallow, 8.5 water depth in deep)
However, if you've got algae, 6 gallons of 8% bleach is not enough for a 50k pool and barely enough for a 30k pool.
