Thread: Need HELP! with new Intex pool
    May 2014
    Walterboro, SC
    Default Need HELP! with new Intex pool
    We recently purchased a 24' Intex metal frame pool off craigslist. PO had a Hayward sand filter & pump with a chlorine discharge system, which I didn't reuse the chlorine discharger.
    I didn't "want" a chlorine pool due to my wife's sensitive skin, so I decided to go salt... without doing a lot of reading first.
    By measurement this pool should be between 12,000 to 15,000 gallons at over 90% capacity. We filled it with our normal well water, added 5 40# bags of pool salt crystals, and the kids couldn't wait to get in. They swam for 2 days before I could get the refill sand for the filter & get it up & running.
    Now its day 4, and I have a green pool. Been running the filter all night, and its cleaner of course, but getting greener. AND WE HAVE MY SON'S 7TH BIRTHDAY POOL PARTY ON SATURDAY!!!
    We don't have a pool store in our town anymore, so I can't have it professionally tested for about a week until I can get to one.
    I now see that I need a salt chlorine generator to use salt. I can't get one right away.
    I read that I need to "shock" the pool. Can I just start using chlorine system shock since I'm not using a chlorine generator? Can I add a little chlorine to the water to sanitize it?
    Help, Help, Help...
    I know I screwed up, now I need your expertise to fix it...
    Default Re: Need HELP! with new Intex pool
    Sorry I didn't get to this sooner. But the truth is, on Intex or other soft-side pools, you can not clean up algae in 2 days: the filters simply are not adequate to the task.
    Do this:
    1. Get a cheap OTO/phenol red testkit, 10 gallons of PLAIN store brand 8% bleach, and 4 boxes of 20 Mule Team borax.
    2. Put your filter on "circulate" -- you don't want to filter the algae as you kill it, but you do want to circulate the water. Turn off all 'generator' elements on your system.
    3. Check your pH. If the pH is below 7.0, add a box of borax. Retest 1 hour after it is all dissolved. Add more till you are above 7.0. If your pH is above 8.0, don't worry about it right now. (If you don't need the borax now, safe it -- it keeps indefinitely.)
    4. Once your pH is above 7.0, add 3 gallons of plain bleach in the evening. (If it's cloudy, and not going to get sunny, you can do it now!) If the pool is DARK green, add 6 gallons. Circulate the pool for 2 hours, and then turn the pump off.
    5. Check the pool in the AM, and test chlorine levels. If you don't get a strong yellow with the OTO, pour another gallon of bleach around the pool. Otherwise, add 3 more gallons that evening, and circulate for 2 hours after.
    6. Tell us what the water looks like after the first dose.
    OK. Additional info.
    + Salt systems ARE chlorine systems; unfortunately the pool biz has a history of describing them in ways that have deceived many pool owners. We call them SWCG's (salt water chlorine generators) to avoid that confusion.
    + I have investigated the issue of sensitive skin and chlorine *extensively* and have not found a SINGLE documented case of chlorine sensitivity.
    Monochloramine, used by some water companies? Yes. Dimethyl hydantoin, used in solid forms of bromine? Yes. Various chloramines, especially on indoor pools, from mismanaging chlorination? Yes.
    But simple chlorine, on outdoor pools? Not even one. Even very high levels (much too high for most swimsuits!) don't damage skin. In fact, "bleach baths" (50 - 100 ppm free chlorine) are a COMMON treatment prescribed by dermatologists for treatment of various skin conditions on both adults and children!
    Odds are, we can teach you how to run the pool so it won't irritate your wife at all. A starting place would be to get a K2006 kit, so you can test your water accurately (you still need the cheap OTO kit), will help. Take a look at the Super-simple recipe for intex pools for some helpful info (http://pool9.net/ssr/) Because of the algae, it won't apply directly, but reading that page will still help.
    You need to keep in mind that if your wife has DRY skin, fresh water is intrinsically drying, and the presence of chlorine, or any other sanitizer, will increase that. If that's the case, some tricks my wife used to use, when she spent up to 4 hours per day in a pool as a water aerobics instructor, may help.
  1. CYA is 0 in Intex 10'x30" pool
    By wteal164 in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-01-2013, 10:37 AM
  2. Intex pool
    By rick2012 in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-09-2012, 12:24 PM
  3. intex pool
    By kimberlysl2 in forum Intex-type Pool Setup & Operations
    Last Post: 04-29-2012, 11:15 PM
  4. Dirt in Pool (Intex)
    By iamconfuzzled in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-03-2010, 10:14 PM
  5. New Intex Pool
    By archdiane in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2006, 11:49 AM
