Thread: Pentair intellichlor upgrade
    May 2014
    Default Pentair intellichlor upgrade
    I currently have a pentair CL20 that has gone bad and am going to replace it.
    My question is would I benefit from moving up to a CL40 & can I still use my original control panel?
    My pool is 18,000 gal so it's pushing the max of the CL20
    Thank you in advance
    Sean
    mas985's Avatar
    Pleasanton, CA
    Default Re: Pentair intellichlor
    The larger SWG should last twice as long and give you some head room so you can reduce run time if you want saving on pump energy.
    Mark
    May 2014
    Thank you.. Is it still okay to use the same power box I have or would I have to change that out as well..
    Do you recommend running it on 40% as opposed to the 60% I was running it on with the CL20
    mas985's Avatar
    Pleasanton, CA
    To get the same chlorine level, you should run the 40 1/2 as much as the 20 because it generates twice the chlorine. So if you were running 60% and you have the correct chlorine level, then 30% should be sufficient.
    The power box should support both cells but check the manual first.
    Mark
    Pentair only has one power center for their IC series. It works OK with the 2 smaller units, but tends to overheat with the IC-60. I have a box fan resting in front of a bank of for power centers driving 4 IC-60 units . . . and the things still get hot.
  1. Hayward or Pentair for VS pump upgrade?
    By jscribn1 in forum Pool Equipment & Operations
    Last Post: 04-13-2013, 10:16 PM
  2. Adjusting Pentair Intellichlor IC40
    By newpoolguy in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-07-2011, 11:22 PM
  3. Intellichlor by Pentair Cell Light not on and other issues
    By TAS17 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-02-2010, 02:45 AM
  4. Anyone familar with Pentair IntelliChlor?
    By mshumack in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-26-2006, 02:59 PM
  5. Aquarite vs Pentair Intellichlor IC40. For Intellitouch system
    By hulla in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-12-2006, 07:14 PM
