Thread: 120,000 Gallon Residential Pool Help!!
    May 2014
    Atlanta
    Default 120,000 Gallon Residential Pool Help!!
    I am trying to find a suitable pool cleaner for my 120,000 gallon residential pool. While I do not know the depth as of right now, I can say it is around 15-20 ft deep and is 57ft.
    I have contacted both Dolphin and Aquabot and have a pretty good understanding of their products but wanted a more in dept recommendation.
    Thank you,
    Default Re: 120,000 Gallon Residential Pool Help!!
    Hardly anyone here, besides me, has any experience with 120k gallon pools. And my experience with pools that size is with commercial pools. If you have a 120k residential pool, I would assume you have a pool service. I'd recommend you get together with your pool guy, and talk to a couple of the companies and get direct recommendations from them.
    Good luck!
    . . . membership updated.
    I should have added this note: you probably don't have a 120,000 gallon pool. If your pool is less than 60' long and 25' wide with a 12' deep end . . . you aren't even close.
    A typical community pool 75' (25 yds) long, 40' wide, with a 3.5' shallow end and a 9' deep end is only 115,000 gallons.
  1. Delta UV systems for outdoor residential pools
    By mnbountyhunter in forum Pool Chemicals & Pool Water Problems
    Last Post: 01-03-2014, 07:53 PM
  2. Do UV systems work for residential pools?
    By abehep in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-13-2013, 12:16 PM
  3. 30ft, 26k gallon AG pool
    By madwil in forum Pool Equipment & Operations
    Last Post: 04-17-2011, 09:25 AM
  4. Spa and ORP/pH controlled Residential salt systems
    By Poolsean in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 12-17-2006, 02:50 AM
  5. Residential Main drains
    By Mark Hunter in forum In-Ground Pool Construction and Repair
    Last Post: 08-08-2006, 05:40 PM
