Results 1 to 10 of 11
Thread: Calcium and sodium question
    May 2013
    Concord,ca
    Default Calcium and sodium question
    I noticed bleach is sodium hypochlorite, my chlorine is calcium..any difference
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    Default Re: Calcium and sodium question
    Yes, different. Cal-hypo adds calcium as well as chlorine. Bleach (sodium hypochlorite) adds a little salt as well as chlorine. Both are fine as long as your calcium hardness level doesn't get too high. In that case, you wouldn't want to use cal-hypo.
    May 2013
    Concord,ca
    thanks for getting back
    Once they are dissolve in the pool they are fine, but never EVER mix them! (can you say "kaBOOM!"?)
    May 2013
    Concord,ca
    No Carl I was not going to mix just add slowly one at a time and wait a few between adding. Thanks much
    If you add bleach to gain chlorine, why would you want to add cal-hypo afterwards? As a source of chlorine, you wouldn't need to use them both on the same day. When I said that many people use both, I didn't mean in the same day as that is not needed. What I meant was that some people might use bleach most of the time and then only use cal-hypo occasionally instead of bleach or vice versa. Does that make more sense?
    May 2013
    Concord,ca
    yes it does, I'm experimenting a little. I bought the cal hypo and I had a lot of bleach. I'm just keeping my eye on the chlorine levels closely. I know Big Lots bleach is around 2.7 strength which is nothing BUT the calculator has a place to put that amount in which is great as their bleach is so cheap. Time will tell
    Remember: for 2.7% bleach to be "cheap" it must be no more than 30% of the cost of 8.25% bleach. Otherwise it's actually more expensive--when you consider how much you need to get the same chlorine level in your pool.
    May 2013
    Concord,ca
    Now that makes sense
    I buy "nominal" 12% Liquid Chlorine in 5 gallon carboys for about $19. This store's LC always tests at 14-14.5% strength. If I buy 8.25% ultra bleach chlorine, if it costs more than $1.03/gallon it's more expensive than the LC (assuming 14.5% strength).
  1. Confused on Bleach, Calcium Hypochlorite, and Sodium Dichloroisocyanurate
    By TXREALTOR in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-22-2012, 01:26 PM
  2. 6% sodium hypochlorite vs. 68% calcium hypochlorite for start up?
    By Mtheuck in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-07-2012, 10:44 PM
  3. Calcium chloride and sodium hydrogen carbonate
    By Rkh3 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2011, 09:43 PM
  4. Compare Calcium and Sodium Hypochlorite
    By jereece in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-27-2006, 01:51 PM
  5. Adding sodium bicarbonate AND calcium chloride at the same time
    By thr56 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-23-2006, 03:03 AM
