Results 1 to 10 of 11
Thread: Calcium and sodium question
    Default Re: Calcium and sodium question
    If you add bleach to gain chlorine, why would you want to add cal-hypo afterwards? As a source of chlorine, you wouldn't need to use them both on the same day. When I said that many people use both, I didn't mean in the same day as that is not needed. What I meant was that some people might use bleach most of the time and then only use cal-hypo occasionally instead of bleach or vice versa. Does that make more sense?
    May 2013
    Concord,ca
    yes it does, I'm experimenting a little. I bought the cal hypo and I had a lot of bleach. I'm just keeping my eye on the chlorine levels closely. I know Big Lots bleach is around 2.7 strength which is nothing BUT the calculator has a place to put that amount in which is great as their bleach is so cheap. Time will tell
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    Remember: for 2.7% bleach to be "cheap" it must be no more than 30% of the cost of 8.25% bleach. Otherwise it's actually more expensive--when you consider how much you need to get the same chlorine level in your pool.
    May 2013
    Concord,ca
    Now that makes sense
    I buy "nominal" 12% Liquid Chlorine in 5 gallon carboys for about $19. This store's LC always tests at 14-14.5% strength. If I buy 8.25% ultra bleach chlorine, if it costs more than $1.03/gallon it's more expensive than the LC (assuming 14.5% strength).
    May 2013
    Concord,ca
    the bleach is about 2.7% and walmart brand is 2.75 a gallon. So actually the 2.7 is a little more expensive, and I was checking on the chlorine "feeders" and that doesn't seem to be a good option so I will stock up on walmart
