Remember: for 2.7% bleach to be "cheap" it must be no more than 30% of the cost of 8.25% bleach. Otherwise it's actually more expensive--when you consider how much you need to get the same chlorine level in your pool.
Now that makes sense
13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
I only trust the k-2006 titration is better for me
I buy "nominal" 12% Liquid Chlorine in 5 gallon carboys for about $19. This store's LC always tests at 14-14.5% strength. If I buy 8.25% ultra bleach chlorine, if it costs more than $1.03/gallon it's more expensive than the LC (assuming 14.5% strength).
the bleach is about 2.7% and walmart brand is 2.75 a gallon. So actually the 2.7 is a little more expensive, and I was checking on the chlorine "feeders" and that doesn't seem to be a good option so I will stock up on walmart
