Results 1 to 10 of 14
Thread: Very Green Pool
    mayfield, ks
    Default Very Green Pool
    We have a 25K , vinyl pool, sand filter. I years past we have almost totally used bleach for chlorination. We had a problem this year. It was losing water all winter because of a leak which turned out to be the main drain. The water is totally green now. Yesterday,we pushed some dichlor in (because that's all we had on hand)
    and the top of the water turned a little foamy. Then we put in a quart of polyquat which made patches of green slime appear. I know we need to keep our shock level at about 15ppm. This morning my cya is 50, cl was 2, alk 90, ph was over 8.2 (that's as high as my test kit will go). Should I try to adjust the ph down before I continue to shock? or let it go and worry about keeping the chlorine up to 15? We are running our filter constantly and brushing often. Should I continue to use the dichlor until I get an order of liquid chlorine shipped in?
    16'x36' rectangle 25K gal IG vinyl pool; bleach; Pentair Meteor 26" sand filter; challenger 1 1/2 HP pump; hrs; PS233; rural water ; PF:4.8
    Default Re: Very Green Pool
    Dichlor will continue to add more CYA which you really don't need since a CYA of 50ppm is a good level. However, if you have no liquid chlorine on hand and don't want to make a Walmart run to get some bleach, it is ok to use dichlor for a little while as long as you are aware that the CYA will continue to climb and are ok with that.
    It is also ok to add some muriatic acid now to drop the pH a little but first please read the tab in my signature about using muriatic acid safely. Wait awhile after the addition of the acid before adding the bleach or dichlor and you will be fine.
    mayfield, ks
    Thanks, Watermom. We were gone for the weekend so I am just now getting to read your post. Came home to a blue pool but very cloudy, still can't see the bottom. Is that possibly the dead algae? Should I get some of the flock stuff to get rid of it? or do I just need to be patient? After using dichlor to get to 15, I was happy that today's test for cl. was 12ppm, it didn't fall too much. but ph was 7.0. Don't know why the ph came down. I didn't add any acid. But today, I added about 4 or 5 cups of borax to bring it back up. Didn't do any other tests today. I realized my CYA was going to raise but hope to keep it to a minimum. If I have to I'll drain down and refill to lower Cya later. Hoping to get somewhere to get liquid chlorine tomorrow. We are in the country, 25 miles away from anywhere like walmart.
    Dichlor is very acidic and is probably what is pushing your pH down. Just keep an eye on it. I think you are much better off using some bleach instead of more dichlor so your CYA won't go up any further. Keep your pump running 24/7 while you are trying to clear it up. Don't be too quick to add flocs or other products. It takes time to filter out dead algae. Give it a chance.
    mayfield, ks
    Thanks! I really appreciate the help I get on this forum! I always look here when I am not sure of myself, you do a great job for us pool owners. I will try to be patient, that's difficult for me! ha ha! I will go get some bleach today. I have only used 6% bleach in the past but I saw online that Manard's has a 12% product in a 2 gallon container for $7.48. Thought I might go that route if I can find it.
    May 2013
    Northwest Indiana
    I thought ph testing was inaccurate when fc is over 10... That would explain the apparent dramatic shift in ph for no reason. Might want to let chlorine drop and retest ph...
    Nevermind... Just read that the Taylor kit ph test is ok up to 15ppm chlorine.
    -Eric B. 16x32 rect 14,364 gal AG (Intex Ultra Frame); 14 in sand filter; 1 HP 2800 GPH pump; 8 hrs; Taylor K-2006c, utility water, debris cover
    @Best Guess chart http://pool9.net/cl-cya @K2006 http://pool9.net/testkits
