Results 1 to 10 of 14
Thread: Very Green Pool
    mayfield, ks
    Default Re: Very Green Pool
    Thanks! I really appreciate the help I get on this forum! I always look here when I am not sure of myself, you do a great job for us pool owners. I will try to be patient, that's difficult for me! ha ha! I will go get some bleach today. I have only used 6% bleach in the past but I saw online that Manard's has a 12% product in a 2 gallon container for $7.48. Thought I might go that route if I can find it.
    16'x36' rectangle 25K gal IG vinyl pool; bleach; Pentair Meteor 26" sand filter; challenger 1 1/2 HP pump; hrs; PS233; rural water ; PF:4.8
    May 2013
    Northwest Indiana
    I thought ph testing was inaccurate when fc is over 10... That would explain the apparent dramatic shift in ph for no reason. Might want to let chlorine drop and retest ph...
    Nevermind... Just read that the Taylor kit ph test is ok up to 15ppm chlorine.
    -Eric B. 16x32 rect 14,364 gal AG (Intex Ultra Frame); 14 in sand filter; 1 HP 2800 GPH pump; 8 hrs; Taylor K-2006c, utility water, debris cover
    @Best Guess chart http://pool9.net/cl-cya @K2006 http://pool9.net/testkits
    Quote Originally Posted by Themadczar View Post
    Actually, Ben and I were discussing this very thing yesterday. In the past, there has been an inconsistency about whether it was accurate up to 10 or 15 but I think the final consensus of what we agreed to use is this:
    The Taylor phenol red is good to FC=10. Above that, you can dilute 50:50 with distilled (not tap, spring, 'purified' etc. -- just distilled) water. That will allow accurate pH tests up to FC=20.
    mayfield, ks
    Well, its been over 2 weeks since I started this thread. Our pool is looking a lot better, I can actually see the bottom in the 4-5 ft. deep water, but not in the deep end at all. It is blue but still Pretty cloudy looking. We are still running our sand filter 24/7. I kept the CL level at 15-20 for over a week but have let it go down to 7ppm now because my drop-count test shows I have NO combined chlorine. Ph is better now, 7.6, CYA is 70. My patience is running out. At walmart today I saw some hth clear power pods that say they will take the cloudy out of your water in one day. I am tempted to get some but I'm skeptical. Does anyone know if they would work or would just cause some other problem for me????
    mayfield, ks
    Oh yea, I also put one of those filter socks in the skimmer basket. I was hoping it might help clear out the dead algae (if that is even what my problem is).
    mayfield, ks
    My readings today are FC-8ppm, CYA-70, PH 7.6, ALK-100, CH-140. This is the first time I have EVER tested for CH (because I was under the impression it was not necessary on vinyl pools), so I am not sure I knew what I was doing. When I added the R011L it turned a very light pink, not red, and when I started adding the R-0012 it took 10 drops to get clear and 14 drops to become a very light blue, so I called it 140. * FYI-My regeant is about 5 years old.
