Thread: Liner alignment issues to skimmer after low water level
    May 2014
    MD
    Default Liner alignment issues to skimmer after low water level
    Hello, I have an inground vinyl liner pool at the house I just purchased.
    When starting it up for the first time since owning the house it lost 10k gallons in a day due to broken pipes on the return ports. I dug them up and replaced the fittings but left the water level down and detached the skimmer faceplate so I could get behind the liner to the fittings. Over a couple days, with the faceplate and return flanges off, the liner has sagged and is too low to match up to the fittings or skimmer now. I tried boiling water which helped some but did not get me all the way there. Would it help to lower or raise the water level? Should I just keep trying to pull and stretch with hot water? The liner is 16 years old and has lost some of its elasticity but the same job was just done during the home renovation before I bought it
    (The concrete over the pipes was obviously just cut and replaced and new fittings/pipe installed) so I know its possible some how. Any advice would be great because I'm completely new to pools. Thanks
    Default Re: Liner alignment issues to skimmer after low water level
    . . . membership updated.
    Sorry, but I don't know of a good way to fix a 'shrunk' 16 year old liner. You could try taking the water all the way down (with suction applied UNDER the liner) and then seeing if you can work it into place.
    I'm not a liner expert, and Ted (Waste) isn't posting much, but I'm guessing you'd better start pricing new liners.
    Sorry!
    May 2014
    MD
    I hear you, thanks!
  1. Tear in Liner 3/4" just below water level
    By Winicott in forum Above-Ground Pool Construction & Repair
    Last Post: 07-30-2013, 12:44 PM
  2. Water Level Dropped/Liner Pulling Away-HELP!!
    By anixon7 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-07-2012, 05:12 PM
  3. How to repair an IG liner leak at the skimmer interface and replace skimmer
    By ralph in forum In-Ground Pool Construction and Repair
    Last Post: 02-29-2012, 10:37 AM
  4. Intex AG pool skimmer water level?
    By aylad in forum Above-Ground Pool Construction & Repair
    Last Post: 03-03-2011, 09:58 AM
  5. Skimmer water level
    By day1 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-04-2006, 07:42 PM
