Closed Thread
Thread: opinions sought on wood-burning pool heaters
    May 2012
    Winston-Salem NC
    Default opinions sought on wood-burning pool heaters
    Does anyone have any experience with wood-burning pool heaters? I am intrigued by the idea (and I have a lot of "free" wood, thanks to some awful weather last summer) but it also looks like it could go horribly wrong!
    I want to know if they actually work, and whether their particulate emissions are controlled (like regulated fireplace inserts and stoves) or whether they are basically a fire in a box with some water pipes. I would use it to extend the season, so it wouldn't be in use for more than three months of the year.
    Alison
    16'x40' kidney / "nautilus" 25K gal IG vinyl pool; SWCG; Hayward ProSeries high rate sand filter; Pentair SuperFlo 1HP pump; hrs; Taylor K-2006C; utility water; summer: homemade solar disks; winter: mesh; ; PF:4.8
    Default Re: opinions sought on wood-burning pool heaters
    Quote Originally Posted by alisonquilts View Post
    Exactly.
    Heating water leads to steam. Steam leads to explosions. Explosions lead to dead people.
    There's a reason why there are redundant safety systems on household water heaters . . . but even so, this still happens:
    (http://www.lni.wa.gov/TradesLicensin...-Explosion.jpg)
    I was a licensed master plumber for 25+ years, and I have a degree in engineering management . . . but I'm not sure I'm qualified to design a wood stove based pool water heater.
    There have been some discussions on that topic here, but once I realized how unskilled the original poster was, I killed the discussion. I'm sorry, but that applies to you too: the very question you asked indicates that you lack the experience to pursue this topic safely.
    There are manufactured wood boilers that could be used with reasonable safety, like these:
    http://www.centralboiler.com/e-classic.html
    But they aren't designed to handle pool chemicals, so you have to add a water-to-water stainless or cupro-nickel heat exchanger to the loop.
    ---- Thread closed ----
Closed Thread
