Thread: Chlorine and PH too low
    Default Re: Chlorine and PH too low
    Sounds like you're on the right track.
    Apr 2014
    Rancho Cordova, California
    My pool water is really clean and really clear. You can even see the left over scale on the bottom of the pool. No slime building on walls and when I sweep the bottom it doesn't get cloudy. The pool pump cleans the bottom so well that there is hardly any debris. I use the pool an hour a day and keep the solar cover on the rest of the time.
    6.3k gal AG rectangle; Whisperflo 3/4 HP pump WF3; Pentair CCP-240 cartridge; Rainbow #320 Chlorine Feeder; Intermatic Timer; Solar Cover and reel; Taylor K2006 test kit. PF=19
