Results 1 to 10 of 10
Thread: solar cover reel system
    mommak is offline Registered+ Thread Analyst mommak 0
    May 2014
    Michigan
    Default Re: solar cover reel system
    Can just one person do this? As, most likely it will be myself removing it most of the time.
    Can one person do what ----- use the solar roller cover stick or use roll the cover onto pieces of pvc? Either way, the answer is yes, you should be able to. I can do the cover stick by myself (what I currently use) and I did the pvc rolls by myself before when I used to use that method.
    (Did you find the pics in the thread linked in one of the posts above of the pvc rolls and clips?)
