Re: solar cover reel system
Can one person do what ----- use the solar roller cover stick or use roll the cover onto pieces of pvc? Either way, the answer is yes, you should be able to. I can do the cover stick by myself (what I currently use) and I did the pvc rolls by myself before when I used to use that method.
(Did you find the pics in the thread linked in one of the posts above of the pvc rolls and clips?)
