The 6-way kit can only test chlorine levels up to 5ppm. If you can, you are better off getting a Taylor K2006.
Ah I did not know that... So i guess I will have to Order the Taylor then. Sucks that its 3x the price though...
Yeah but definitely worth it. You won't regret it.![]()
Hi just got my test kit:
pH was less than 7
FC: 1.4PPM
CC: 0
Calcium Hardness: 70ppm
Alkalinity: 40ppm
So I'm currently adding 1 gallon of 8.1% Liquid Bleach to the skimmer every hour till chlorine reaches 5ppm right? As far as PH, that should come up as well, however should i also add Borax as well or should I wait.
Thanks,
Jason
13k gal 24' 52" round AG pool with cartridge filter. PF=9
1. Add borax, a box at a time, till your pH is above 7.0. Allow 1 at least hour of pump ON time, before retesting pH. Add it slowly, to the skimmer, with the pump running.
2. For now, add 1 gallon dose of bleach each evening, directly to the skimmer, but NOT on top of any tabs. (Make sure bleach and tabs NEVER touch!)
3. What is your stabilizer level? If your CYA (stabilizer) is low, chlorine will NOT last through out a day of full sun, no matter how much you add. Instead, if you have swimmers during the day and have low CYA, pour 1/8 to 1/4 gallon doses into the skimmer periodically. This is in ADDITION to your evening gallon. I'd recommend getting a cheap OTO/phenol red kit, for quick testing during the day: add chlorine if you have swimmers and the OTO results aren't medium yellow or darker; skip doses of chlorine test result IS dark yellow.
PoolDoc / Ben
OK great... So here are my newest test results.
PH is now around 7.4 based on my observations and tests.
I added 2 gallons of bleach, which brought my Chlorine levels up to 15ppm (totally should have waited i know)
my CYA level is too low to register anything on the test. Should I buy Cynuric Acid? Or should I just get TriChlor? Or both?
Either way works. I typically just buy it separately.
