Results 1 to 10 of 41
Thread: Filter / Pumps / New Pool
    Default Re: Filter / Pumps / New Pool
    Before you buy a Summer Escapes pool, read this info page about the different soft-side pools: http://pool9.net/sspool-info/
    And, read the Super Simple recipe page: http://pool9.net/ssr/
    None of the filter and pump combos that come with the soft side pools are great, but Intex does have some upgrade options. Summer Escapes does not, and I don't think the adapters that allow you to use standard pool gear with Intex pools will work on Summer Escapes. However, IF you get the Unicel cartridges for a Summer Escapes AND you are careful to avoid algae, the water will stay reasonably clear.
    + Chlorine is the primary (and best) pool sanitizer (kills germs), algaecide (kills algae), and oxidizer (burns up 'goo')
    + Sand is the filter media inside sand filters. Other filter media include fabric cartridges and DE powder.
    + Salt is just table salt -- sodium chloride. BUT SWCG's (salt water chlorine generators) use electricity to convert the "chloride" into "chlorine".
    . . . . membership updated.
    I just bought the 24' version of this pool, so I can provide some information.
    First off the built in clorinator it is refering to is a joke. Basicly the filters that they sell have a hollow middle and they recommend you put 1 inch clorine tablets in there. It in no way produces clorine.
    The included filter is the bare minium and very noisy. You will have to run it a lot longer than a stronger filter to get any results and have to watch your water carefully. My orignial plan was to use the filter until it broke and then upgrade. I have multiple years of frame pool experience and after one month I have already decide this filter is not worth running. The included filter system could not filter the dirt from the bottom of my pool. It would pass through the filter system right back to the bottom of my pool. Nothing ticks me off more than to vacuum the bottom of the pool and see a trail of dirt coming out of the filter system.
    You can connect a different filter to the outlet of the existing hole exit with clamps. You will have to play a bit with hose sizes depending on what filter you upgrade to.
    May 2014
    Thank you both!
    May 2014
    Again, thank you. Some things came UP, but based on the links, I finally got an Intex 18' x 48" Ultra Frame pool with Krystal Clear Filter Pump. It has a 90% capacity of 6,423 gallons. I will now re-read the Super Simple recipe page link. Hopefully do all the proper tests and have it up for next weekend. I'm sure I'll have plenty of more questions.
    Ben - you mentioned that Intex has some good filter upgrade options. I saw a Krystal Clear saltwater system at the store. Is this recommended? From what you posted, if I am correct, this converts salt to chlorine. What is the benefit compared to regular chlorine filter?
    Rich
