Results 1 to 10 of 10
Thread: Pool opening - unsure if Black Algae-HELP
    gfritz1 is offline Registered+ Thread Analyst gfritz1 0
    May 2010
    Pennsylvania
    Default Pool opening - unsure if Black Algae-HELP
    Intalled pump and got water circulating a week ago but left winter Loop Lok cover on . Check water and FC was at 9.0 and water looked clear .Have been running roughly a week as in Pa still very cold .Today took off the winter cover and water was clear .Vacuum and got everything up but noticed that we had a lot of stain or something on vinyl liner. We have been on bleach for three years and pool is a 23000 gal inground with a DE filter . We tried brushing and it did not work so I got out a pad (Scotch ) and use it on a applicator and it is removing the stain and it appears to be black but it will be a lot of scrubbing . I did shock before getting out the pad. I will post readings after checking water in morning but PH was 8.0 the other day . Chrlorine FC was at 5.0 but CYA appeared to be below 30 .Have not added anything else like Poly 60 yet . Thoughts -next steps
    16x32 rectangle 23K gal IG pool; trichlor feeder; Hayward HE-65 DE filter; Hayward 1.5 pump; 12hrs; Taylor Kit - can test FC-CC-CYA-ALK-Hardness; utility water;; PF:5.2
    Been on bleach since 2012
    May 2010
    Pennsylvania
    Default Re: Pool opening - unsure if Black Algae-HELP
    Tested chemicals - PH 8.0+ ,FC 7.2 CC .2 TC 7.4, Alk 110 ,Hard 120,CYA 60
    At first glance the obvious thing you need to do is get your pH down to the low 7's. Chlorine loses effectiveness as pH gets higher--rather rapidly!
    I have troubles with your volume calculation. Unless your pool averages 6' deep I don't see how you get 23,000 gallons. For example: If your pool is 4' deep, you'd have 16000 gallons. You'd have to have half the pool as a deep end of 8' to get 23,000 gallons. Volume = L x W x D x 7.48, where D is the water depth and 7.48 is the number of gallons per cubic foot.
    May 2010
    Pennsylvania
    Carl my profile I is correct except it is a inground not a above ground .It is a 16x32 with a 8 ft deep end and also a set of steps off the side thus the calculation of 23000. I started lowering the PH last night and will check this morning . So other than lowering PH and brushing any other suggestions?
    OK, but your sig line says "23k gal AG pool" so I figured either the AG or 23K had to be wrong.
    Ok: Looks like you're testing FC and CC with the 25mil line, and every drop counting .2ppm. Don't. Use the 10mil line where every drop counts .5ppm--it will save your reagents and you don't need anymore accuracy than .5. Most of us never use the 25mil line.
    Once you get pH down, test FC again and CC again. Don't bother with T/A, CH or even CYA. T/A will be lower, no problem. CH is irrelevant with a vinyl pool--assuming it's vinyl. If it's not you can worry about CH later.
    Then you're going to want to raise your FC to at least 20ppm and keep it there. You can use bleach or, if you want, cal-hypo powder. If your pool is hard-sided, not vinyl, cal-hypo's a good choice because you'll want to get CH to 200-40ppm eventually. Do not use Di-Chlor powder or Tri-chlor tabs as both add CYA and yours is high enough.
    Once you get FC to 20ppm, you'll want to follow the standard algae fighting procedure laid out here: Test FC 3x a day, especially after the sun passes in the evening, and add chlorine to bring it back to 20ppm.
    You'll want to vacuum the dead algae to waste once a day, and brush the walls and bottom once a day as well. You'll lots of POPP--"pool owner patience and persistence".
    If you use bleach, 1 gallon of 8.25% adds about 3.5/3.6ppm of chlorine to your 23k pool. 1 gallon of 6% adds 2.6ppm of FC. Adjust accordingly. Never can remember exactly how many pounds of Cal-hypo powder you need to increase FC.
    gfritz1,
    Click on the "edit my signature" tab in my signature below and you can fix your signature line.
    Also, I believe Carl meant CH level 200-400 in his post above instead of 200-40!
    May 2010
    Pennsylvania
    will do now facing a bigger problem .When starting my Hayward unit this year the pimp started yard .Had to give it a little tender loving tap. It was purchased in 2008 which was my 1st replacement .It sounded loud so ordered a replacement motor Sunday .Today while staining the pool deck it died . New motor will be here late Wednesday ,When it rain it pours. Grandchildren coming home for Memorial Day so pressure on !
    May 2010
    Pennsylvania
    Ok PH is down to 7.6 and chlorine has been elevated for three days . Today added Poly Quat 60 by Kem Tech . In working on pool the last week the stain is getting better but far from gone .Hopefully On Sunday can actually get in the water and be more aggressive with brushing and et better idea of what is going on. I have noticed the following :
    1.If I take shock and put in sock and set on the stain it removes it . I tried in numerous areas and t lighten or removed in all areas
    2.I had some ascorbic acid from last year and when did the same sock trick it also lighten it or removed it
    Is it possible that what I have is a huge metal stain on the pool ? Makes no sense why only on the deep ends but? I had have had metal stains in the past and last year went through the metal removal process with success .But I hear stores where it can come back worst then before?
    May 2010
    Pennsylvania
    Some Corrections - 1 >ascorbic acid "does not remove the stains" that occupy the majority of the pool . (2) Confirmed again this morning that the HTH calcium hypochlorite "does completely remove the stain"
    I went to work on the fiberglass steps this morning to conduct my test and thus am now based on everything you said confirmed it is a "organic stain " that is causing me the concern .
    We have had a extremely wet spring in Pa after a extremely hard winter .The water table is as high as I can recall and water is laying in my yard places it never has in almost 40 years . Have to assume much water behind my liner on the inground pool .
    Check readings this morning and update PH 7.4 FC 11.5 CC0 TC 11.5 Alkalinity 120 and Hardness only 100 . Concern is that CYA is creeping up with using the powder HTH as now at 60 and with history of chlorine demand really hate to use the HTH . Line is within a year or two of replacement and is badly wrinkled in spots so by no way is it "smooth" . I ended up with water behind the liner and when sucking the liner back and removing the water it was left wrinkled or high "PH" has taken toll?
    So have so far super shocked and kept chlorine levels high. Brushed and vacuum ever day . Treated with Poly Quat 60 yesterday . Any suggestions other then brush and vacuum? I really like the results of the HTH in a sock and going after the dark spots as it really is like instant clean but again worried about CYA ? Waiting for your expert opinion
    Cal-hypo does not have CYA in it.
  1. Killing black algae while pool is drained.
    By Phillbo in forum Dealing with Algae & Slime
    Last Post: 04-25-2014, 11:59 PM
  2. Small Black dots in salt pool. Black algae?
    By jeanne3434 in forum Dealing with Algae & Slime
    Last Post: 04-06-2014, 05:58 PM
  3. black algae in pool
    By bluekiwi in forum Dealing with Algae & Slime
    Last Post: 10-10-2013, 02:40 PM
  4. Black algae in empty pool
    By tark101 in forum Dealing with Algae & Slime
    Last Post: 05-08-2007, 12:15 PM
  5. Black Algae in Saltwater Pool
    By sb2323 in forum Dealing with Algae & Slime
    Last Post: 05-09-2006, 02:26 PM
