Closed Thread
Results 1 to 10 of 44
Thread: Argggghhhh!!!
    no1ford is offline ** No working email address ** Thread Analyst no1ford 0
    Default Re: Argggghhhh!!!
    ok-so I can see maybe 6 inches farther down and have a turqouise color. very pretty! I am just going to let the filter run for a few days and keep levels good and see if now with the nylon on if things filter through. I do have a very small pump-so maybe the days I was given is unrealistic. I will update when I have change!
    Downingtown, PA
    The best thing you can do is get that Chlorine into shock level and keep it there throughout the day.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    It had been at 10 + for two weeks, Can't I let it drop yet?
    Still looks the same! Blue and cloudy-I'll keep it the pump a running!
    Can I use bleach in my 18 x 48 intex pool? The pool store is out of chlorine. What do you use for ph plus and minus and clarifier?
    Bleach is chlorine. You should read this on the sister website PoolSolutions
    and when you are done read EVERYTHING ESLE that you can on that site!
    http://www.poolsolutions.com/gd/grocery.html
    If you follow the advice on there you should have no need for clairfier! The only things you will need from the poolstore are Stabilizer and Muriatic Acid (although you can also find those at such places as Home Depot, Walmart, and Hardware stores!)
    AND GET YOURSELF A TEST KIT. LOOK FOR THE AQUACHEM 6 WAY AT WALMART OR KMART. Best test kit out there for under $20
    If you had done this from the beginning you would be swimming already!
    No1ford - Please go back and reread all the advice you have been given. You asked if bleach can be used as chlorine? In one of my responses above (post #13) I suggested to you that you use bleach. I agree with Waterbear that you need to go and read at www.poolsolutions.com to learn the basics. Also, read through a lot of the other threads on the forum. You will learn so much that can help you manage your pool.
    This thread is getting pretty long - we are up to post #38 already. We are always glad to help but we need you to focus closely on following the advice we are giving and to inform yourself as much as possible by reading PoolSolutions. Hopefully, you will see much improvement very soon.
Closed Thread
