Thread: Old Concrete Pool
    May 2014
    Jax Fla
    Default Old Concrete Pool
    Buying a house with old (25 year old concrete pool) realtor pool guy says can't be saved. Must be ripped out and entire new pool put in. Any way to save it?
    Default Re: Old Concrete Pool
    Seriously?
    There is no way to answer that, when we haven't even seen the pool. Your options are either to fix it yourself -- in which case, you should know whether you can do it -- or hire it done. If you're planning to hire it done, call some guys, pay them a service call, and ask them to 'ball-park' a quote on a new pool and on a rehab.
    Pool construction prices in S. Florida tend to be much lower than in other parts of the country. I'm not sure about Jacksonville, though.
    May 2014
    Jax Fla
    Thank you for your response. I understand that it's almost impossible to assess without looking at pool. I guess I just wanted to know that if it was even a possibility to restore a concrete pool. Having a background in construction. But NO pool expertise, I thought it would take very serious issues for anything concrete to be beyond repair
    But I realize pools can be a different beast
    If you've got a construction background, look for structural cracks in the pool, and for plumbing problems. Both of those can be very expensive to repair.
  1. concrete bottom pool with stainless sides, sealant for the concrete/wall joint?
    By kentuckynet in forum In-Ground Pool Construction and Repair
    Last Post: 04-14-2014, 04:21 PM
  2. Concrete pool stains
    By maggie2712 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-13-2013, 07:15 PM
  3. Concrete pool leaks
    By Vaporize in forum In-Ground Pool Construction and Repair
    Last Post: 05-22-2012, 12:41 AM
  4. 50 year old concrete pool.
    By jeffjr464 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-05-2011, 07:37 PM
  5. Ca and alk requirements for concrete pool
    By TRHOD12 in forum Dealing with Alkalinity and Calcium
    Last Post: 06-01-2010, 04:46 AM
