Thread: New Member ..Question about CYA test
    May 2014
    Florida
    Red face New Member ..Question about CYA test
    Hello, I have been reading many post on this. I am confused at how to do this test. When doing the test and pouring the solution into the test bottle with black dot...do you wait till you no longer see the black dot? Or do you stop when the black dot just starts to fade?
    I was doing it when I no longer seen the dot but the pool store told me that you do it when it starts to fade then stop....it was odd because with there test they came out at 100-CYA and when they used my tester it came out 80-CYA
    Any help would be appreciated. Thank you
    Default Re: New Member ..Question about CYA test
    There are videos here: http://pool9.net/tk-guide/
    One tip: when testing CYA, you need outdoor -- but NOT direct -- light.
    Jun 2013
    Central Florida
    Default
    You can pour the solution back into the squeeze bottle and repeat the test over and over.
    Just to be clear, I don't mean that you can re-use the solution the next time you want to do the CYA test, but you can repeat the test with the solution you have mixed a number of times in the current testing session. This allows you to "master" reading the test, because it is difficult to determine when the dot disappears.
  1. New Member with dichlor question
    By azpkumom in forum General Interest
    Last Post: 07-25-2013, 07:33 PM
  2. New member with a question about bad filters.
    By Xercister in forum General Interest
    Last Post: 07-18-2013, 09:01 PM
  3. New member with a question
    By PapaX5 in forum Intex-type Pool Setup & Operations
    Last Post: 06-10-2013, 01:58 PM
  4. New Member Question
    By BRush3054 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-08-2012, 10:04 PM
  5. New Member Question regarding SeaBlue Pools
    By KYHoopsfan in forum In-Ground Pool Construction and Repair
    Last Post: 06-27-2011, 08:50 AM
