Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 30
Thread: di chlor question
    May 2013
    Concord,ca
    Default di chlor question
    If I needed a kick of cya in my pool, would adding a bag of granular di-chlor do it? I know sounds like a pain but I just found a little algae starting to bloom in one corner and want it to stop. BTW I was thinking of a floater but I have a fiberglass pool and heard NO on fiberglass Thank You Dave G.
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    May 2013
    Concord,ca
    Default Re: di chlor question
    Thanks Watermom, BTW still wating for the pic of your other pup
    Quote Originally Posted by dansdad View Post
    Oh, yeah. I forgot about that. One of these days, I'll do it.
    May 2013
    Concord,ca
    hey watermom this stuff I have is 99% sodium dichloro s trianz something. Will it blow up or is it safe to use/ I normally use chlorine just wanted to check it out Thanks Dave G
    What brand is it/where did you get it?
    May 2013
    Concord,ca
    It's called clear view shimmer-n shock made in USA by Oreq. I got it at my pool store 3 rd generation owned not Leslie's or any general store
    I know nothing about that type. I'm a skeptic so let's run it past Ben and see what he thinks.
    May 2013
    Concord,ca
    Thanks watermom
    You're welcome. I've asked Ben to offer an opinion. He should be along shortly.
  1. Anyone se Lo-chlor?
    By poolbee in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-30-2008, 11:43 AM
  2. CYA and tri-chlor
    By adesalvo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-09-2007, 02:22 AM
  3. chlor brite?
    By graciec in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-16-2006, 02:59 PM
